Hi
In Work window is not posible type a name with two word, like JOSE LUIS, when I type space, the cursor tab to next field. I can only type JOSE.
Thanks for this software.
(Version 6.43)
Error in Name field?
Re: Error in Name field?
Yes, this is correct.
The idea was that we use normally no double names in ham radio and
that the space is then available as hotkey to return quickly to the call sign field.
It would not be a problem to change this behavior.
What is the opinion of other users about this?
Hi,
I think that the space running as a hotkey is a very fine solution. To put double names into the name field the easiest way is to use the stroke (-) instead the space!
<Shift> Space???
73 de Juergen
73 de Juergen
Shift+Space
- for blank or
- for selection of call sign field?
- for blank or
Ok, thats is a idea... I report this "no error" but another simple solution is type JOSELUIS, and all ok.
Hi,
I added in UcxLog 6.44 Beta 3 the possibility to enter blanks in the QSO-Work-Name field using the key '_'.
