Logbook Printing
MD0MDI
Logbook Printing
Beitrag von MD0MDI »
Hi Ben and anyone else watching...
Is there a setting to make the logbook print out in Landscape anywhere?
I have tried different printers that are attached and also Fine Print pdfFactory 3.0 Pro, and even setting each of these to 'Landscape' do not seem to have any effect on the print-outs!
It is just that in Portrait mode the column 'Name/QTH/Remarks' rolls into the Callsign and that also has no space between it and the QSL information.
All the best, James (MD0MDI)
Re: Logbook Printing
Hi James,
I never used this logbook print, may be you are the only one, who tried to use it.
Landscape is not supported because it needs a second print layout, the print function is not so "intelligent" to scale the columns to the paper size, sri.
Are you sure that you really need this print? Then I have to check it ...
MD0MDI
Nope not essential! I was just looking to keeping a paper copy in the shack, if it is too much work then don't do it just for my sake, if others ask then maybe it would be worth it, thanks anyway...
James (MD0MDI)
Hello James,
I double-checked the "QSO - Print Log" function with format "A4 Portrait".
I could not see such an error with very long name/qth/rem information. It is truncated at the right side and fits into the column.
I can't imagine how it can roll into the callsign because there are the 2 RST columns between callsign and name column.
DJ4KW
Logbuch-Auszug Cut&Paste in Textfile oder eine E-Mail
Beitrag von DJ4KW »
was ist die einfachste Möglichkeit, ein paar hintereinander liegende Zeilen aus dem Log in ein Textdokument zu bekommen, um etwa zu dokumentieren, welche QSOs man zu einer bestimmten Zeit gefahren oder beim Versagen eines QSL-Wunschs nicht gefahren hat? Ich stelle mir so etwas vor, wie bei QSO / EDIT LOG /SHORT den Bereich mit der Maus zu markieren, CUT und PASTE in ein Textfile oder eine E-Mail.
73 Gerd DJ4KW V31YN
Hallo Gerd,
geht es mit QSO - Export - ASCII nicht?
DJ4KW
Beitrag von DJ4KW »
Danke für den Hinweis auf die von der Programmkonstruktion her empfohlene Vorgehensweise. Über ein Text-File zu gehen geht schnell und ergibt die besten Weiterverarbeitungsmöglichkeiten. Sicher gibt es auch umständlichere Wege, die ich vermeiden wollte.
