QSL Layout forgotten
YO5LD
Beitrag von YO5LD »
Hello,
My QSL Layout got forgotten.
I redid the layout, but it always resets back to default after each program restart.
Even doing an export of the layout after changing then reimporting it won't bring back the modified layout.
What could be wrong?
Re: QSL Layout forgotten
Hello,
I assume your virus scanner is blocking the writing of the file ...ST2.
YO5LD
Beitrag von YO5LD »
I don't think so :-(
The export works fine, I see the file being created in EXPORT/LAYOUT01.ST2.
If I import this file, I don't get back the same layout that was "exported".
Also, I do see the YO5LD.ST2 file being modified on disk whenever I do any operation (like LoTW export or so).
No user has ever had a problem like this.
So it makes no sense to assume an error in Ucxlog.
Normally you do the change in "Settings - QSL Layout" and confirm with "Ok", That's all.
Note that every operator has its own layout.
I can not investigate your files because I'm traveling next 2 weeks.
YO5LD
Beitrag von YO5LD »
Yes, that's what I'm doing. but after a program restart I do see the ST2 file timestamp being modified, but the Layout forgotten.
Not super urgent to me, but would like to understand what is happening or how can I reset everything without loosing all of my other settings..
Weirdly enough, even exporting the QSL layout and then importing it back won't bring back the original layout.
Hello,
I checked it and could not see any problem.
Which UcxLog version do you use ?
Did you use "Operators" ?
Each operator has its own QSL layout, it is stored in the file <operator_name>.ST2.
I found the bug.
If there is any text element in the layout with an absurd height of 1 pixel (= invisible) , a new error-detection mechanism overreacts, sri.
This is fixed in 8.52 Beta 3, which will be released later today.
8.52 Beta 3 uploaded.
YO5LD
Beitrag von YO5LD »
It is now working indeed.
Thanks!
