History Version 8
Re: History Version 8
Version 8.33
Contest
- Updated: YOTA (points)
- Updated: VFDB-Kontest (Sonder-DOK)
Contest - Work
- A call sign that has already been logged will not only be displayed
after entry as "Double", but also registered 2s later as "Double"
in the bandmap.
Contest - Score Upload
- "CQ Contest" renamed to "Live Score" (contest.run),
Upload destination updated
- Contest IDs updated
Member lists updated
- RDA.TXT
- FIRAC.TXT
- FOC.TXT
- HSC.TXT
Country list
- New/changed special calls
TX0QRP FO
GB6WWA GW
GB8WWA GI
KL2A/7 W
TO5LA FH
EM1EHR CE9
EM1UTQ CE9
R81AWD UA3
TX7W FO/A
TO8FP FP
Nun schon 2 Fehlalarme, das wird immer schlimmer werden ...
Already 2 false alarms, this is only going to get worse ...
Leider habe ich keinen Weg gefunden, Cynet und Rising wegen der Fehlalarme zu kontaktieren :(
Die 8.34 Beta 8 endlich mal wieder ohne jeden Fehlalarm :D
Version 8.34
Contest
- New: World Wide Patagonia DX
Scan - Text
- Results list sorted by callsign
Settings - Station - General
- New: Scaling (All windows): 100...200 %
Windows - Bandmap
- New check box "Sum": Show band overview column
- 40m Fone extended to 7300 (if set in "Station-Bandplan")
Windows - DX Cluster - Contest
- "Show only - Multipliers": Messages for own callsign suppressed
Network
- State display for "Data Rate" and "Log deficit" improved.
- Match of own locators checked (important for VHF/UHF)
- RDA.TXT
- FOC.TXT
- HSC.TXT
- VHSC.TXT
- MC-AL.TXT
- AGCW.TXT
- DIG.TXT
- CWOPS.TXT
Fixed errors
- Scan - Distance: Band selectable again
Country list
XQ7UP/9 CE9
TO7PX FR
EM1/UW5EHR CE9
N5J KH5 20240801-
N2W KP2 20240103-20240201
AO75IB EA6
AO75IC EA8
AO75MC EA9
E51TLM E5/S
TO60CSG FY 20240406-20240721
Version 8.35
Contest
- New: MRAI - DL6RAI Memorial
- Updated: DARC Hessen HF (MIXED added)
Settings - Station - Transceiver - CAT - Offset
- Negative values allowed
Example: SDR Console and QO-100: Display=10GHz but TX frequency=2.3GHz
Band=2300 Offset/kHz= -8089500 --> Display=2.3GHz
View - Recorded Audio
- English lettering restored
- RDA.TXT
- FOC.TXT
- HSC.TXT
Country list
3D2CCC 3D2/C
GB6WW GM
RP79H UA9
RP79PK UA9
RP79V UA9
GB0SRW GM
GB8VED GM
N5J KH5 20240805-20240820
K8K KH8 20240626-20240709
3D2Z 3D2/R 20241115-20241204
Gesperrt
