Audio Recording
oz1bii
Audio Recording
Beitrag von oz1bii » Samstag 10. Februar 2018, 23:18
Hi Ben
I see that there is a plugin-program (QSOrder by K3IT) for the N1MM+ logger that will help splitting the received audio into small files including audio from every single logged QSO.
Do you know that and could that be an option in UCXLog ?
https://github.com/k3it/qsorder/releases
73 de OZ1BII/OU2I Henning
CW is all I need
Re: Audio Recording
Beitrag von DL7UCX » Sonntag 11. Februar 2018, 07:49
Hello Henning,
I don't know why I should do that "splitting".
Using menu "View - Recorded audio" you can quickly listen to any wanted time.
oz1bii
Re: Audio Recording
Beitrag von oz1bii » Sonntag 11. Februar 2018, 19:12
Hello Ben
Sure - no problem to listen inside the program.
But if I want to put a single QSO on the net or send it to the operator, I have to take the Audio into a program and cut it out.
And there is the homepage: https://qsorder.hamradiomap.com/ Where you can listen to QSO's Try to check DL7UCX QSO with TK0C :wink: ;o)
Could be funny to upload a whole split-audio Contest there.
Just a thought - nothing more :)
CW is all I need
DF1LX
Re: Audio Recording
Beitrag von DF1LX » Montag 5. März 2018, 14:31
That should be easy to realize - UCXlog needs to sent all worked QSO as a XML string via UDP to QSorder (like N1MM+ - definition of the XML string can be found in the online documentation). Nothing more.
Re: Audio Recording
Beitrag von DL7UCX » Montag 5. März 2018, 14:39
den UDP-Server oder -Client zu implementieren und einzurichten ist vielleicht eine Winzigkeit komplizierter als "easy".
Ich sehe hier immer noch nicht den Bedarf und Nutzen bei mehreren UcxLog-Usern.
