History Version 7
Re: History Version 7
Beitrag von DL7UCX » Dienstag 2. April 2019, 20:17
Version 7.93
Contest:
- Updated: Stew Perry Topband Distance Challenge
- Updated: DSW-Kurzcontest
- Updated: Mecklenburg-Vorpommern-Contest
- Updated: DARC YL-Aktivitäts-Party
- Updated: Deutschland-Contest
- Updated: Worked All Provinces of China
- Updated: DARC Nord-Contest (S-DOKs)
Member lists updated
- RDA.TXT
Country list
- New/changed special calls
RI1ANB VP8/H
RI1ANV CE9 -20190228
HF0POL VP8/H 19780101-20160331
VP8CTR CE9
EM1U CE9
Beitrag von DL7UCX » Dienstag 4. Juni 2019, 09:32
Version 7.94
Modes
- New: FT4 (ADIF: Submode of MFSK)
Contest:
New: RSGB May
Updated : SPDX RTTY
Revival: GACW World Wide South America
Updated: IARU Region 1 Fieldday
TRX control
- New: Kenwood TS-890
QSO - Work
- Last "Band RX", "Propagation Mode", "Satellite Name" stored
Hotkeys
- Shift+Pause / Ctrl+E: PTT on/off (only Fone)
- LOTW.TXT
- RDA.TXT
- AGCW.TXT
- DIG.TXT
- DOK.TXT
Country list
- "Macedonia" changed to "North Macedonia"
9M19TEA 9M2
DP1POL/p CE9
FO/KE1B FO
VK2FBBB/VK9 VK9N
GB0BOC GM
TO19A FR
RP74AB UA9
RP74DG UA9
RP74GS UA9
RP74KM UA9
RP74P UA9
RP74PO UA9
RP74SD UA9
RP74TG UA9
RP74AZ UA9
RP74GI UA9
RP74GR UA9
RP74MP UA9
RP74V UA9
RA60PD UA9
RK4PA/9 UA9
RP74AR UA9
RP74DT UA9
RP74GB UA9
RP74IM UA9
RP74KT UA9
RP74LL UA9
RP74U UA9
RP74UF UA9
R17J?? UA9
R17PPN UA9
R17UGRA UA9
Beitrag von DL7UCX » Donnerstag 4. Juli 2019, 09:11
Version 7.95
Contest:
New: CQ World-Wide VHF
Updated: Marconi Memorial HF CW
IARU HF Championship
- List of HQ stations (IARU.TXT) updated (from https://bit.ly/itudtb)
IOTA list updated
- New: AS-206, AS-207, OC-298, OC-299, OC-300, SA-101
Rotor control Yaesu via CAT:
- Command "X4" (full speed) added
Oblast detection - New suffixes:
- *1I: Komi
- *4G: Penzenskaya obl.
- *4K: Samarskaya obl.
- RDA.TXT
- LOTW.TXT
Country list
GB19CGM GM
GB2ORM GW
R26RRC UA9
GB19CJ GJ
GB19SG GW
GB19CG GU
GB19CGI GI
GB19CGW GW
GB19CIM GJ
GB19CNI GI
GB19CS GM
GB19CW GW
R205NEW UA9
VK9APX VK9L 20190801-20190810
TO5M FP 20190810-20190818
VP8/VP8DXU VP8/S 20200220-20200305
R2019CG UA9
R53ICGA UA9
R53ICGB UA9
R53ICGC UA9
R53ICGJ UA9
R53ICGW UA9
Beitrag von DL7UCX » Montag 9. September 2019, 15:44
Version 7.96
Contest:
- New: ALPE-ADRIA VHF
- New: VFDB-DLPX
- Updated: Komi-Ruhrgebiet Memoriam
- Updated: Ruhrgebiet Contest
- Updated: IARU Region 1 Fieldday OZ
- Updated: Africa All-Mode International DX
- Updated: SAC
DX Cluster window
- New file SUPPRESS.TXT for suppression of callsigns possible
Settings - Station
- New tab "Band Data Port"
- Microham Band Data: Separate COM port
Settings - QSL Layout
- Remarks: New keyword <sat>
TRX CAT control
- ICOM: Mode "DSTAR" added
WSJT-X ADIF import
- Wrong data "SRX (Received Serial)" in no-contest logs ignored
Locator list
- LCTR_MMM.TXT updated September 2019
Source: MMMonVHF (Make More Miles on VHF)
File msloc_db.dbmh from http://www.mmmonvhf.de/download.php/
- RDA.TXT
- LOTW.TXT
- FT8DMC.TXT (new)
- FIRAC.TXT
Fixed errors
- Windows - DX Cluster: Bands above 70cm fixed
Country list
- WAE list
4U500M 4U_V
R53ICGF UA9
R53ICGV UA9
FO/AI5P FO 20190722-20190729
FO/W6NV FO 20190719-20190721
GB0OGC GI
TX2A FO/A 20190723-20190729
TO80SP FP 20191002-20191014
TO9W FS
R63RRC UA9
R73QQ UA9
UE90PR UA3
TO8FTDM FG
9M59MS 9M6
9M60* 9M2
9M60MS 9M6
TX7A F 19891001-19891130
VK9IR VK9N 20090720-20090727
VK9WB VK9C 19900529-19900605
VP8CBA VP8/F 20020212-20020213
ZK1ETW E5/S
ZK1ETW E5/N 20011014-20011020
ZK1XV E5/S
ZK1XV E5/N 19870517-19870604
DP1ANF VP8/H
VP8CDJ VP8/G
VP8CKB VP8/G
9M4LHT 9M2
E51SFS E5/S
GB2MUC GM
GB2TNL GM
4U500M OE
9M62* 9M2
9M62MQ 9M6
9M62MS 9M6
TX7T FO/M
9M16KING 9M2
9M4COO 9M2
GB4BIT GW
Gesperrt
