LOTW QSL downloading with more than one call sign?
Verfasst: Sonntag 16. März 2014, 07:44
von LB2EG
Hello,
I am on Lotw with two call signs, my old (la4sga) and my new (lb2eg).
In the UcxLog dialog window, downloading confirmed Qsos from ARRL-Lotw, I can only put in one callsign at the time ("Own Call Sign"). This procedure means that I first must write in la4sga, do the download, then erase la4sga and write in lb2eg, and then do the download again.
Have I missed a smart alternative way doing this?
Regards,
LB2EG Richard
Re: LOTW QSL downloading with more than one call sign?
Verfasst: Sonntag 16. März 2014, 09:37
Hello Richard,
LOTW requires 1 callsign for download, so UcxLog can only send 1 callsign.
Old callsigns can be linked in LOTW to the actual callsign, then QSLs of both callsigns count together for DXCC.
But I fear that this will only download the QSLs of the request call sign because in the ADIF report file from LOTW is the own call sign only contained once in the header, not in each qso.
Verfasst: Sonntag 16. März 2014, 09:50
von LB2EG
DL7UCX hat geschrieben:Hello Richard,
Ben,
Yes my old an new callsign are linked in lotw database.
Mybe ucxlog could store more callsigns in that dialogue window, letting the user choose which to use?
Richard
Verfasst: Sonntag 16. März 2014, 11:17
Put it on the To-Do-List ...
Verfasst: Mittwoch 11. November 2015, 13:40
von LB2EG
DL7UCX hat geschrieben:Put it on the To-Do-List ...
Hello again Ben,
hopefully, this LOTW request is still on your to-do-list.
73 de LB2EG Richard
Verfasst: Mittwoch 11. November 2015, 14:55
Hello Richard,
It is still in the to-do-list.
The implementation is not simple, because a second call sign was not planned in the internal data structures.
Unfortunately no other user supported your request.
Verfasst: Mittwoch 11. November 2015, 19:02
von LB2EG
Ok, but what about a drop down/pop up box where the user put his callsigns to choose from?
This way the user does not need to erase and fill inn the different call signs in the call sign field, when using two or more call signs with the same log.
Richard
Verfasst: Mittwoch 11. November 2015, 20:20
Self-evident a drop down list.
With 2 or 3 or 4 or 5 or more call signs ... ?
The program must store this in a limited settings file.
Pse qrx, there are more important features on the to-do-list.
Verfasst: Mittwoch 11. November 2015, 20:42
von LB2EG
DL7UCX hat geschrieben:Self-evident a drop down list.
As I am the only one that has requested that feature until now, it is time being only necessary with space for two calls in the list:) ... But if you make space for 2-4 calls, I guess most operators will be satisfied.
No problem with some time span until implemented.
73 LB2EG Richard
Verfasst: Donnerstag 1. Dezember 2016, 22:15
von LB2EG
Hello Ben,
Has this request moved forward on your to-do-list?
Regards,
Richard LB2EG
Verfasst: Freitag 2. Dezember 2016, 16:49
Hello Richard,
Please try Version 7.69 Beta 7.
Verfasst: Freitag 2. Dezember 2016, 17:31
von LB2EG
Just what I wanted.
Thanks!
Richard
