History Version 7
Re: History Version 7
Version 7.63
Contest
- Updated: DARC Funkertag Juni-Party
Windows - Received Digital
- "QSY" function corrected
Member lists updated
- AGCW.TXT
- DIG.TXT
- FOC.TXT
- HSC.TXT
COUNTRY.TXT Version 7.63
- New/changed special calls
E51EXA E5/S
Version 7.64
Contest
- New: SA Sprint
- New: Westfalen Sued Aktiv.
- New: TARA's Grid Dip psk-rtty Shinding
- Updated: RSGB Low Power (20m added)
- Updated: DMC RTTY (Multiplier changed to "Prefix")
- Updated: Ruhrgebiet Contest
Export - ADIF
- ADIF field <CNTY> supplied from logged "USA-CA" award data
Settings - Station - Special
- New check box "Simple COM port IO method" to fix COM port driver errors
- LOTW.TXT
Fixed errors
- Edit Full: TAB function in mode list corrected
COUNTRY.TXT Version 7.64
- Prefix OW moved from Denmark to Faroe Is.
R80??? UA3 20160612-20160831
GB2DRC GM
GB4BOJ GW
R85KFF UA3
R270SR UA9
LS4AA/F LU
9M4CC 9M2
R66IOTA UA9
RD16CW UA9
RN16CW UA9
RQ16CW UA9
R1716K UA9
R1716M UA9
R1716O UA9
R1716S UA9
R430LT UA9
R70ASIA UA9
TO200SPM FP
R95KOMI UA3
R870T UA3
Version 7.65
QSO - Export - ADIF/ASCII/CSV
- Export begin date/time preset to last export end
- Default file name contains begin date/time
View/Scan
- Keys 0-9/A-Z select table row beginning with this key
Rotor control
- New: M2 RC2800
- LOTW.TXT
Fixed errors
- "Contest- Work - Multis needed on bands" corrected
- Take over of DX cluster entries by up/down arrow keys suppressed
during "Undo"
COUNTRY.TXT Version 7.65
GB1BPL GW
GB3HLS GW
R300MJ UA9
R300MSK UA9
RZ16WF UA9
RA/DK2AI UA3
E51Q E5/S
TO5FP FP
R23RRC UA9
9M4RM 9M2
JD1YBV JD1/O
9M59MK 9M2
9M59MP 9M2
9M59MA 9M2
9M59MC 9M2
9M59MD 9M2
9M59MM 9M2
9M59MN 9M2
9M59MR 9M2
9M59MW 9M6
9M59MY 9M2
Version 7.66
Contest
- New: TARA Rumble PSK
- Updated: VFDB-Aktivitaetstage, VFDB Contest
- Updated: UBA PSK63 Prefix
- Deleted: Nordsee-Aktivitaetstag (Exchange too long)
Settings - Operator
- Selection simplified
Export - ADIF
- "RDA" award entry exported to field "CNTY"
QSO/Contest - Group Modify
- New modification field "Rcvd RST"
- Progress bar added
Cloud Download / Synchronize Ucx Logs
Start icon parameter "Log directory" saved to Registry
- FIRAC.TXT
- AGCW.TXT
- FOC.TXT
- HSC.TXT
- DIG.TXT
- LOTW.TXT
- RTC.TXT (RTC liquidated)
COUNTRY.TXT Version 7.66
RA/EA3NT UA3
RA/EA5KA UA3
9M4CAM 9M2
FT3YL CE9
VK9PH VK9N
KH2N W 19920101-
KL0S W 20070101-
Version 7.67
Contest
- New: Holzhammer-Contest
- New: SARTG New Year RTTY
- Updated: Schwaben-Contest
- Updated: UK-EI DX
QSL - Import ADIF print list
- "Via direct" sorted to begin of print list and marked with "CBA"
Settings - Station - Other Interfaces - CW/SSB
- New check box "Send CW as sound"
(Send CW from soundcard, TRX mode SSB/Data)
Manager list
- OQRS list updated
- LOTW.TXT
- DOK.TXT
COUNTRY.TXT Version 7.67
GB1MSG GD
GB4DUK GM
TX8JOTA FK
GB0CSC GI
TO4OC FM
TO6ABM FM
R80RRA UA3
Version 7.68
Contest
- Deleted: Saar-Contest
QSO - Worked window
- New pop-up menu item: "Show QSOs chronological (not by band)"
QSL - Received/Send - Export
- New choice item: "Export to ADIF file + LOTW upload"
- MF.TXT
- LOTW.TXT
Fixed errors
- ICOM(Trcv=ON): Isolated wrong mode at program start
- WAE DX Contest: Cabrillo format of sent QTCs corrected
COUNTRY.TXT Version 7.68
- Rufzeichenprefix für "Franz Josef Land - R1FJ"
von R1F in R1FJ geändert
GB1BAF GW
R80PVB UA3
Version 7.69
Contest
- *** Important rule change: Helvetia !!!
- Updated: RSGB 2nd 1.8MHz
- Updated: UFT-YL-CW
- New: UFT Toutes Bandes
Windows - DX Cluster
- Fields for band and mode selection redesigned
- New check box: "Show multiple RBN/Skimmer messages"
QSL - LOTW - Download:
- Drop-Down list for "Own callsign" (max. 5 entries stored)
View - QSO statistics
- New field "QSOs / Year"
Windows - Call Data Base - XML / QRZ.COM - Login Data
- New field "HTTPS"
- MF.TXT
COUNTRY.TXT Version 7.69
GB2LXX GM
VP8DPJ CE9
VP8DPK VP8/G
9M4LI 9M2
FO/K7AR FO/A
TX8F FK
NP4H W
NP4H KP4 20161122-20161206
Version 7.70
QSO - Work
- New: Real-time QSO upload to "Clublog"
Contest - Work - Score upload
- New: Fields for "Login", "Password" and "HTTPS"
- Contest names updated - 111 contests supported
Settings - Station - Special - Contest
- New field "Off-Time Calculation Threshold"
- FISTS.TXT
- LIDSCW.TXT
- LOTW.TXT
- AGCW.TXT
- DIG.TXT
- FOC.TXT
- HSC.TXT
- MF.TXT
COUNTRY.TXT Version 7.70
A61Q/MD A6
RM17NY UA9
RU17NY UA9
RZ17NY UA9
Version 7.71
Contest
- New: Belgium Digital Modes RTTY WW
- New: RCWC 4 Seasons
- New: ARRL Field day
- Updated: VFDB Contests
Windows - Bandmap
- 60m band possible
Settings - QSL Layout - Freq. format
- Format "Band (MHz)" for 60m changed from "X.XXX" to "X.X"
CW sending via CAT
- New for Kenwood and Flexradio with restrictions
Clublog Upload
- "Operator" callsign added
- EPC.TXT
COUNTRY.TXT Version 7.71
8J60JARE CE9
GB2KW GM
GB8KW GM
R870M UA3
E51ADD E5/S
E51AMF E5/N
OA0MP VP8/H
Version 7.72
QSL
- New: Clublog - Export + Upload ADIF file
- New: Clublog - Import CSV file (from RSGB IOTA)
Contest
- *** Essential update: AGCW Happy New Year - Cabrillo Format
- Updated: DTC (Cabrillo)
QSO - Edit - Full:
- New: QSL "C" = Clublog (IOTA) confirmed
Settings - Station - Colors /QSL
- New: Background color and column "Clublog" for IOTA confirmation
View - IOTA
- Display of Clublog confirmations
"Worked" lists
- Display of "QSL sent/rcvd (Card, LOTW, eQSL, Clublog)" revised
- LOTW.TXT
- CWOPS.TXT
- AGCW.TXT
- DIG.TXT
- FOC.TXT
- DOK.TXT
Fixed errors
- "RCWC 4 Seasons" contest: Point calculation corrected
- NCDXF beacons: KH6WO changed to KH6RS
- FT-991, FT-3000: "PTT via CAT" fixed
COUNTRY.TXT Version 7.72
LU4CJM/Z VP8/H
TX5T FO/A 20170220-20170302
TO7D FG
4X50UK/SK 4X
GB6WW GM 20050507-20050526
IQ0AL IS
J42004Q SV9
MR0FAL GU
ZK1AKX E5/N 20021001-20021025
ZK1AKX E5/S 20021029-20021111
R1336FO UA2
R680FBO UA2
AO150V removed
4K5ZI UR 19900101-19921231
AM890OM EA8
GB0CI GI 19930611-19930613
GB0ON GJ 19970724-19970728
R10RTRS/2 UA2
R16LEV UA9
R2016A UA9
R25ARCK/4 UA9
UF6V/R6CZ 4L 20151126-20151129
UF6VM 4L -19940831
YU4WU E7 19911016-20050730
YZ4IZ E7 19911016-20031130
YT4I E7
4O4D YU -20060628
RU9CK/4 UA9
UZ2F* UR
Version 7.73
Mode lists
- MSK144 added
Contest - Work (New/Continue)
- New Button "Compare":
Real-time comparison with previous contest,
QSO/Points/Multiplier difference total and per band
Contest - REG1TEST (EDI) logs
- Former DARC classes "01"..."26" replaced by "Single"/"Multi"
Windows - Map
- Mouse click sets temporary direction and starts rotor turn
- Button "Set Watch+Colors": New pop-up menu "Show only watch messages"
- Watch list: New search options: CQ Zone, ITU Zone, DXCC Entity
QSL - Clublog - Export + Upload ADIF file
- After QSL receive (Card/LOTW) the QSO will be uploaded again also
with selection "Not exported ..." (if inside "Period")
Manager - OQRS
- Entry "OQRS" from file MANAGER.TXT now shown as "$" + ManagerName
Scan - Member
- Take over of US states into all QSOs from list "W.TXT" possible
Hotkeys
- Shift+Esc changed to Shift+Del:
If message from DX cluster window was taken over and is unchanged,
clear QSO data and go back to frequency/mode before.
OQRS list updated
IOTA list updated
- LOTW.TXT
- FIRAC.TXT
Fixed errors
- QSL print: Band name "60m"
- RTTY contests: Frequency correction by Fldigi audio carrier stabilized
COUNTRY.TXT Version 7.73
RV1CC/4/M UA9
R2017M UA3
R80RTL UA3
RM94AE UA3
TO3Z FG
R80UPOL UA3
RA/DK8DX UA9
9M4IOTA 9M2
R870O UA3
Version 7.74
Contest
- New: RSGB International Sprint
- New: YUDX HF contest (new rules)
- Updated: Kazakhstan DX renamed to UN DX
- Updated: RSGB First 1.8MHz
- Updated: A.R.I. International DX
- Updated: CQ-M
- REG1TEST format: PBand values updated, national characters blocked
- Deleted:
EPC PSK63 QSO Party
EPC RUSSIA DX
EPC WW DX
UK DX RTTY
CIS DX QPSK63
CQ SA SSB
GACW World Wide South America
Makrothen
SYLRA
TARA Rumble PSK
UBA Low Band Winter
UK DX BPSK63
DARC UKW-QRP-Wettbewerb
Windows
- New: Add Bandmap: Opens up to 5 additional bandmap windows
Main window
- Band/Mode table: Shown bands free adjustable
- Suppress: New check box "NCDXF"
- Watch list: Wildcard * possible at "Show=NOT"
- EPC.TXT
- AGCW.TXT
- DIG.TXT
- FOC.TXT
- HSC.TXT
- LOTW.TXT
- MDXC.TXT
Fixed errors
- Watch list: Band/mode filter for options CQ/ITU Zone and DXCC
- Russian DX contest, Cabrillo: TX ID added
- Date/time pickers unreadable with Windows 10 "Creators"-Version 1703
- UKSMG Summer contest: Point display corrected
Country list
- Kure I. KH7K --> not deleted
- Midway I. KH4 --> not deleted
E51ANQ E5/S
E51KTA E5/S
RA/DF8DX UA9
E51LYC E5/N
RI1ANO VP8/H
RY83HN UA3
RO25TN UA9
RK56GC UA9
R71RRC UA9
GB0GLV GW
RT60RT UA9
TX5X FO 20180310-20180317
VK9VKL VK9X
VK9AA VK9X 20170624-20170701
FO/JI1JKW FO/A 20170503-20170504
GB0COA GI
GB0GLS GI
PY0NY PY0F
VK9MAV VK
R15JMG UA9
FO/F6CTF FO 20170602-20170903
GB5GEO GW
Version 7.75
- LOTW.TXT
Fixed errors
- DL-DX RTTY contest: Multiplier calculation corrected
- Date input field improved
- File error at first installation
Country list
TX5JF FO
E51XYL E5/S
R15JRA UA9
R15URGA UA9
Version 7.76
All dialog windows now bilingual (also in German)
Modes
- New: FT8
ADIF
- New: DARC_DOK
Contest
- New: Scottish DX
- Updated: DARC R-(Nordrhein)-Contest
- Deleted:
RTC-Party
TARA Grid Dip
TARA Melee
Contest - Work
- "Score Upload" extended to "Contest Online Score Board"
(contestonlinescore.com)
QSO/Contest - Edit - Full
- New button "Clublog": Searches callsign data on clublog website
Windows - Database
- Selection of "Internal/Standard Browser" moved to
"Settings-Station-Special"
Scan
- No more restriction of number of found QSOs per band/mode
View - Countries - File Export - CFD for most wanted list HF
- Several prefixes changed at DARC's request
Master list
- MASTER_CT.TXT updated (Release 2017.08.02.00 by Stu Phillips, K6TU)
- AGCW.TXT
- DIG.TXT
- FOC.TXT
- HSC.TXT
- LOTW.TXT
Fixed errors
- Helvetia-VHF/UHF/Microwaves contest: REG1TEST format
Country list
UE08F UA2
UE80AR UA3
RD17CW UA9
RN17CW UA9
RQ17CW UA9
GB4RME GW
FO/IZ2ZTQ FO/M 20170518-20170606
R17CWH UA9
RJ17CW UA9
RK17CW UA9
TX5EG FO/M 20170729-20170806
E51GHS E5/S
RO17CW UA9
4U1A OE
Version 7.77
Contest
- Rules changed: TRC DX !!!
- New: CVA
- Updated: UBA ON
- Deleted: EU Sprint
Bandmap
- 50 MHz Digital extended to 50.500
Settings - Station - Other interfaces - RTTY
- New check box "AFSK freq. = TX carr."
- FIRAC.TXT
- QCWA.TXT
- LOTW.TXT
Fixed errors
- WAE: Compare function falsifies QTC number
- Locator list problem with national Windows settings for OZ
Country list
UB5O/M UA9 20170803-20170812
UE40CZF UA9
R870K UA3
9M4LHA 9M2
E51JHQ E5/S
GB5TAM GM
R15JSU UA9
RU9CK/4/M UA9
UZ2F* UA2 -19931231
UA4RX/1 R1FJ 20170902-20180831
HF0ARC VP8/H 20170815-20171023
GB2SAA GM
Gesperrt
